Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Twist the mounting plate clockwise, then lift to remove it.
Having removed the four Phillips screws in the previous step, separate the assembly as shown.
Using the craft knife, prise and loosen the three tabs shown from their mounting points. This will make removing the battery contacts easier in the next step.
Remove the battery contacts from their mounts, taking care to separate the soldered electrical wires without damaging nearby parts. Note the two smaller contacts which connect to the circuit board.
Using the craft knife, slice off the black plastic extrusions at the indicated positions. These tabs secure the circuit board to the main assembly.
Lift and separate the power switch from the main assembly.
Using a similar technique to that exercised in step 9, slice off the clear plastic extrusions at the indicated positions. These extrusions secure the lens, case and reflector elements.
3 Комментариев
LED Flashlight is the best ever app i have ever use...I love it..
flashlight is very important for android user.We are providing best flashlight with different feature.You can visit flashlight with extra feature,download and enjoy it.
download best led torch light
