Введение
This guide will help you with the process of replacing the Wi-Fi PCI Card in your device.
Выберете то, что вам нужно
Unplug the two wires that are on the Wi-Fi PCI card (white & black).
Unscrew the single screw in front of the Wi-Fi PCI card using the Phillips #0 screwdriver.
Еще один человек закончил это руководство.
Один комментарий
Can this slot be used for anything other than the Wifi PCI card? Such as a TC SUNBOW 512GB 42mm? Or perhaps another 42mm SSD?
