Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Turn off the cell phone and place face down on a flat surface.
While sliding the gray tab up, lift battery up and away from the cell phone.
Use a Spudger to remove the two front plastic covers to reveal screws.
Pry off the screen front cover with a small flathead screwdriver.
Insert a small flathead screwdriver into the hinge and separate hinge connection.
Pry off the speaker which is glued on to the front cover using a small flathead screwdriver.
Remove remaining portion of the front case from the flexible circuit board.
Unscrew the four screws on the back case using a T6 Torx Screwdriver.
Pull the back cover straight off the phone using your thumb and forefinger.
Remove the LCD Screen from the phone case and replace with a new LCD screen.
2 участников успешно повторили данное руководство.
