LG Ally VS740 Speaker Replacement
Выберете то, что вам нужно
    1. LG Ally VS740 Speaker Replacement, Speaker: шаг 1, изображение 1 из 2 LG Ally VS740 Speaker Replacement, Speaker: шаг 1, изображение 2 из 2
      • Hold phone in hand, then flip to battery pack
      • Take off battery cover
      Спросите у FixBot
      Добавить комментарий
    2. LG Ally VS740 Speaker Replacement: шаг 2, изображение 1 из 1
      • Remove battery
      • Locate the six surrounding screws located on the edge of the inner compartment, including the two screws on the metal piece where the battery was once placed.
      Спросите у FixBot
    3. LG Ally VS740 Speaker Replacement: шаг 3, изображение 1 из 1
      • Slide the phone open. Notice on the edges around the keyboard, there is a thick casing. Remove this casing, instructions below…
      • Placing two dominant fingers on the back plate where the battery was, use your thumb finger nail (or prying utensil) and place it on the edge of this thin casing. Firmly, push down with your finger nail (prying utensil) around the casing from left to right. Disconnect casing from keyboard section. Flip the phone over and remove it.
      Спросите у FixBot
    4. LG Ally VS740 Speaker Replacement: шаг 4, изображение 1 из 2 LG Ally VS740 Speaker Replacement: шаг 4, изображение 2 из 2
      • Using your prying tool, lift the green circuit board platform off the black casing and gently disconnect the connection point between the tether and the green circuit board.
      • Flip phone over, and notice where the camera lies on the other side, there are three small clips connecting a black casing over the section of the phone. Gently using your hands or the prying tool, take these clips off.
      Спросите у FixBot
    5. LG Ally VS740 Speaker Replacement: шаг 5, изображение 1 из 3 LG Ally VS740 Speaker Replacement: шаг 5, изображение 2 из 3 LG Ally VS740 Speaker Replacement: шаг 5, изображение 3 из 3
      • Holding the recently removed black casing in your hand notice that silver circular module connected to the casing.
      • Using your prying tool gently press down on one of the golden springs coming out of it. Apply enough pressure so the speaker module is ripped off its sticky foundation.
      • Once this is removed take the new speaker and fit it in at the same place. Be sure to apply a suitable amount of pressure with both finger and thumb to ensure it is stuck to the sticky tape once again.
      • Follow the steps backwards to put the phone back together.
      Спросите у FixBot
Заключение
3 человек успешно провели ремонт по этому руководству.
Michael Caplan
Участник с: 10/21/14
102 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 5-6, Vijaybhaskar Fall 2014 Участник UMass Dartmouth, Team 5-6, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G6
3 членов
Автор 48 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 29
За всё время: 711
