Введение
The guide was develop to help replace the screen of a LG Aristo, also known as LGMS210 or MS210.
Выберете то, что вам нужно
Turn off the device and make sure you are working on a flat, lit surface.
Remove the battery by prying it up with a fingernail or opening tool from the bottom edge.
Detach the cables from the press fit connectors.
You can lift them up with you finger or you can use tweezers (optional).
To reassemble your device, follow these instructions in reverse order. I hope that these steps have helped you with your issue.
2 участников успешно повторили данное руководство.
