Введение
This guide will teach you how to remove the back speaker, located directly underneath the back cover. Only minimal disassembly is required.
Выберете то, что вам нужно
On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
Set the back cover with the speaker aside.
Use the plastic opening tool to pry the speaker cover off of the phone.
Еще один человек закончил это руководство.
