Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Power down the cell phone by pressing and holding down the red "end call" button.
Turn the phone screen-down so you are looking at the back cover.
Slide the back cover down using your finger to remove the cover from the phone.
Press downward while pulling outward to remove the battery.
Remove all four screws on the back of the phone using a Phillips #00 screwdriver.
Pull the phone back cover off once all the tabs are released.
Push the contents of the phone away from the hardshell case by applying pressure to the keypad with both thumbs.
The hardshell case is separated from the rest of the phone.
Separate keypad from circuit board by turning it upside down and allowing it to fall off.
Use thumb to release both white clips at the top of the circuit board.
Once both clips are released, turn over the circuit board so that the display is facing upward.
Carefully lift the display from the left side and open to the right.
