Введение
This guide explains how to remove the motherboard from your LG CG225.
Выберете то, что вам нужно
Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
Carefully disconnect the gold ribbon cable from the upper right corner of the motherboard.
Почти готово!
Заключение
