Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
The front housing is the glossy front cover of the phone which can get scratched easily.
Запчасти
Детали не указаны.
  1. Insert one of the plastic opening tools between the silver and plastic black parts of the speaker at the top of the phone. Pry off the black plastic part to separate it from the silver part.
    • Insert one of the plastic opening tools between the silver and plastic black parts of the speaker at the top of the phone.
    • Pry off the black plastic part to separate it from the silver part.
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Use the screwdriver to remove four 3.0 mm Phillips #00 screws as shown.
    • Use the screwdriver to remove four 3.0 mm Phillips #00 screws as shown.
  4. Insert a the plastic opening tool in between the silver and black seam of the phone casing. Take off the front housing by running the plastic opening tool around the perimeter of the phone.
    • Insert a the plastic opening tool in between the silver and black seam of the phone casing.
    • Take off the front housing by running the plastic opening tool around the perimeter of the phone.
Заключение
Zack Mintzer
Участник с: 16.04.2013
1 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 21-55, Johann Spring 2013 Участник Cal Poly, Team 21-55, Johann Spring 2013
CPSU-JOHANN-S13S21G55
4 членов
Автор 12 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 330
