Введение
The LG Chocolate VX 8500
You will learn how to replace the back cover of an LG Chocolate
The back cover of the LG chocolate helps the battery stay in place, and without the back cover the battery can potentially fall out which can create a whole separate problem.
If your device haves a swollen battery or its showing symptoms of a swollen battery make sure you don’t put it on the charger. Run the battery down as low as you can to reduce any risk of fire or smoke
Выберете то, что вам нужно
Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
Use a Phillips #00 screwdriver to unscrew the four Phillips #00 screws on the four corners under the battery to unfasten the back case from the phone.
Take the case off by using a plastic opening tool.
Continue using the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
