Запчасти
Детали не указаны.
Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
Unscrew the four Phillips 00 screws on the four corners under the battery to unfasten the back case from the phone.
Pry the case off using a plastic opening tool.
Continue working the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
Pry off the plastic tabs that cover two screws, as shown in the first picture.
Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
Pry the front speaker and wireless receiver out of the front case using a spudger.
Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
The LCD Board in now accessible.
