Инструменты
Запчасти
Детали не указаны.
Этот шаг не переведен. Помогите перевести
Insert the plastic opener into the slot at the top of the device.
Apply gentle pressure with the plastic tool to pop the back case off.
Use the plastic opener to lift, and remove, the device battery.
Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
