Введение
If the QWERTY silicon keypad is worn out or damaged, it is replaceable. It requires time and a lot of disassembling.
Выберете то, что вам нужно
Remove the five 3.0mm Phillips #000 screws along the edge of the rear case.
Remove the two 2.9 mm Phillips #000 screws that are slightly off-centered to the right.
Hold the motherboard from the top and bottom and slowly lift the motherboard until you feel a pull.
Once the motherboard is lifted , rotate the motherboard up 90 degrees to the right.
Еще один человек закончил это руководство.
