Введение
If your LG EnV Touch VX11000 shuts down unexpectedly or the screen is broken or malfunctioning, you may need to replace the motherboard. This guide will show you how to replace the motherboard in an LG EnV Touch VX11000.
Выберете то, что вам нужно
Slide the release latch down and toward you while lifting up on the left side of the battery cover.
Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
Using both of your hands, gently pry out the motherboard by pulling up on both ends.
3 участников успешно повторили данное руководство.
