Введение
If the camera button or the volume buttons on your LG EnV Touch VX11000 are jammed, stuck, or unresponsive, you may need to replace them. This guide will show you how to replace the camera and volume buttons on an LG EnV Touch VX11000.
Выберете то, что вам нужно
Slide the release latch down and toward you while lifting up on the left side of the battery cover.
Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
