Введение
The circuit board and full key board are attached and must be installed together as one unit. Do not try to separate them.
Выберете то, что вам нужно
Place the phone so the screen side is facing down.
Locate the latch at the end of the phone, opposite of the camera.
Remove the 5 screw covers on the back of the phone using a Push Pin.
With a Phillips #00 Screwdriver, remove the five 3.44 mm screws that were under the screw covers.
Also with a Phillips #00 Screwdriver, remove the screw that was revealed once the battery was removed.
Starting at the card slot or charger port for greater ease, pry off the colored casing from the back of the phone using the Plastic Pry Tool (or a finger nail may work).
Remove the back colored casing and set it to the side.
