LG EnV VX9900 Circuit Board and Full Key Board Replacement
Выберете то, что вам нужно
  1. LG EnV VX9900 Circuit Board and Full Key Board Replacement, Battery: шаг 1, изображение 1 из 1
    • Place the phone so the screen side is facing down.
    • Locate the latch at the end of the phone, opposite of the camera.
  2. LG EnV VX9900 Circuit Board and Full Key Board Replacement: шаг 2, изображение 1 из 1
    • Push/pull the latch away from the camera, causing the battery to pop out.
  3. LG EnV VX9900 Circuit Board and Full Key Board Replacement: шаг 3, изображение 1 из 1
    • Remove the battery.
  4. LG EnV VX9900 Circuit Board and Full Key Board Replacement, Circuit Board and Full Key Board: шаг 4, изображение 1 из 2 LG EnV VX9900 Circuit Board and Full Key Board Replacement, Circuit Board and Full Key Board: шаг 4, изображение 2 из 2
    • Remove the 5 screw covers on the back of the phone using a Push Pin.
  5. LG EnV VX9900 Circuit Board and Full Key Board Replacement: шаг 5, изображение 1 из 1
    • With a Phillips #00 Screwdriver, remove the five 3.44 mm screws that were under the screw covers.
    • Also with a Phillips #00 Screwdriver, remove the screw that was revealed once the battery was removed.
  6. LG EnV VX9900 Circuit Board and Full Key Board Replacement: шаг 6, изображение 1 из 2 LG EnV VX9900 Circuit Board and Full Key Board Replacement: шаг 6, изображение 2 из 2
    • Open the phone.
  7. LG EnV VX9900 Circuit Board and Full Key Board Replacement: шаг 7, изображение 1 из 2 LG EnV VX9900 Circuit Board and Full Key Board Replacement: шаг 7, изображение 2 из 2
    • Starting at the card slot or charger port for greater ease, pry off the colored casing from the back of the phone using the Plastic Pry Tool (or a finger nail may work).
    • Prying open the part just to the left of the right hinge can be difficult.
    • Remove the back colored casing and set it to the side.
  8. LG EnV VX9900 Circuit Board and Full Key Board Replacement: шаг 8, изображение 1 из 2 LG EnV VX9900 Circuit Board and Full Key Board Replacement: шаг 8, изображение 2 из 2
    • Gently pry and detach the connection located near the hinge with fingers.
  9. LG EnV VX9900 Circuit Board and Full Key Board Replacement: шаг 9, изображение 1 из 2 LG EnV VX9900 Circuit Board and Full Key Board Replacement: шаг 9, изображение 2 из 2
    • The circuit board and the key board will be attached, as shown in the second picture.
    • Lift them both out from the rest of the phone.
    • Do not try to the detach key board pad from the circuit board. They are replaced as a unit.
Заключение
Stephanie Villavicencio
Участник с: 04/05/12
28 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 15-15, Forte Spring 2012 Участник Cal Poly, Team 15-15, Forte Spring 2012
CPSU-FORTE-S12S15G15
5 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 18
За всё время: 1,253
