Введение
Phone batteries die out gradually after extensive use and multiple charge cycles. If you notice your battery dying out faster than usual, it is potentially due to an issue with the battery.
If you think the battery is the issue with your device not powering on, use this guide to remove and replace a battery in your LG Enact (LG-VS890).
Make sure your device is switched off before beginning.
Выберете то, что вам нужно
Open the back cover by prying into the bottom tab with an iFixit opening tool.
4 участников успешно повторили данное руководство.
