Введение
If you need to replace the audio jack in your LG Encore GT550, follow this guide.
Выберете то, что вам нужно
Turn the device over so the backside is facing up.
Use your fingers or an opening tool to remove the back cover in order to expose the battery.
Use your fingers or a spudger to remove the battery. Lift it from the side opposite of the camera.
Use a Phillips #0 screwdriver to remove six screws around the perimeter of the phone.
Place the opening tool in the seam of the device and pry around the perimeter to separate the top case from the bottom case.
Place the opening tool on the top on the device between the phone casing and motherboard.
Separate the screen and the motherboard.
Еще один человек закончил это руководство.
