Введение
If you've dropped your LG Fortune 2 and noticed screen cracks or greenish imperfections (backlight bleed), it may be time to replace your screen. The process is very straightforward, requires two tools, and will help salvage your phone. Don't overpay for a professional or buy a new phone. Instead say "I fix it" and use this guide.
Выберете то, что вам нужно
Use the slit on the bottom left side of the phone to open the back cover using your hand.
Use the groove at the bottom of the phone to remove the battery.
Remove the twelve 4 mm screws on the back paneling using a Phillips #000 screwdriver.
Use the plastic opening tool to release the flex cable.
Pry off the front camera located above the SIM card slot using the plastic opening tool.
Use the plastic opening tool to pry off the motherboard from the rest of the device.
Use the plastic opening tool to remove the ear speaker on the underside of the device.
Remove the headphone jack using the plastic opening tool.
Remove the volume rocker/button on the side of the phone using the plastic opening tool.
Disconnect the loudspeaker antenna on the bottom of the phone using the plastic opening tool.
Scrape off the small rubber piece from the antenna.
