LG Fortune Motherboard Replacement
Выберете то, что вам нужно
  1. LG Fortune Motherboard Replacement, Battery: шаг 1, изображение 1 из 2 LG Fortune Motherboard Replacement, Battery: шаг 1, изображение 2 из 2
    • Use the slit on the bottom right side of the phone to open the back cover of your phone.
    • It will be the bottom left of the phone if looking at it from the back.
    • Slowly pry the back cover off the phone starting from the bottom up to the top.
  2. LG Fortune Motherboard Replacement: шаг 2, изображение 1 из 2 LG Fortune Motherboard Replacement: шаг 2, изображение 2 из 2
    • Use the slot in the middle of the bottom edge of the battery to pry it up and out of the case.
  3. LG Fortune Motherboard Replacement, Motherboard: шаг 3, изображение 1 из 3 LG Fortune Motherboard Replacement, Motherboard: шаг 3, изображение 2 из 3 LG Fortune Motherboard Replacement, Motherboard: шаг 3, изображение 3 из 3
    • Using a PH000 screwdriver, remove the ten 4mm screws on the back panelling.
    • Remove the back panelling from the device with your fingers or a spudger.
    • Work slowly side to side to release this back casing and expose the motherboard.
  4. LG Fortune Motherboard Replacement: шаг 4, изображение 1 из 1
    • Unplug the video card from the motherboard with a spudger or plastic opening tool.
    • Using the metal spudger as shown in the photos has the potential to damage your device.
  5. LG Fortune Motherboard Replacement: шаг 5, изображение 1 из 1
    • Unplug the front facing camera press fit connector from the motherboard by prying upwards with a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photos could potentially damage your device.
  6. LG Fortune Motherboard Replacement: шаг 6, изображение 1 из 1
    • Unplug the rear facing camera ribbon cable from the motherboard by prying up the press fit connector with a spudger.
    • Using a metal spudger as shown in the photos has the potential to damage your device. Choose an ESD safe tool instead.
  7. LG Fortune Motherboard Replacement: шаг 7, изображение 1 из 1
    • Use the spudger to pry off the motherboard from the rest of the device on the top left corner down to the bottom right corner
Заключение
Cori Johnson
Участник с: 04/08/19
537 Репутация
Автор 5 руководств
Команда
Eastern Washington University, Team S1-G5, Rowley Spring 2019 Участник Eastern Washington University, Team S1-G5, Rowley Spring 2019
EWU-ROWLEY-S19S1G5
3 членов
Автор 14 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 14
За всё время: 731
