LG Fortune Rear Camera Replacement
Выберете то, что вам нужно
  1. LG Fortune Rear Camera Replacement, Battery: шаг 1, изображение 1 из 2 LG Fortune Rear Camera Replacement, Battery: шаг 1, изображение 2 из 2
    • Use the slit on the bottom right side of the phone to open the back cover of your phone.
    • It will be the bottom left of the phone if looking at it from the back.
    • Slowly pry the back cover off the phone starting from the bottom up to the top.
  2. LG Fortune Rear Camera Replacement: шаг 2, изображение 1 из 2 LG Fortune Rear Camera Replacement: шаг 2, изображение 2 из 2
    • Use the slot in the middle of the bottom edge of the battery to pry it up and out of the case.
  3. LG Fortune Rear Camera Replacement, Motherboard: шаг 3, изображение 1 из 3 LG Fortune Rear Camera Replacement, Motherboard: шаг 3, изображение 2 из 3 LG Fortune Rear Camera Replacement, Motherboard: шаг 3, изображение 3 из 3
    • Using a PH000 screwdriver, remove the ten 4mm screws on the back panelling.
    • Remove the back panelling from the device with your fingers or a spudger.
    • Work slowly side to side to release this back casing and expose the motherboard.
  4. LG Fortune Rear Camera Replacement: шаг 4, изображение 1 из 1
    • Unplug the video card from the motherboard with a spudger or plastic opening tool.
    • Using the metal spudger as shown in the photos has the potential to damage your device.
  5. LG Fortune Rear Camera Replacement: шаг 5, изображение 1 из 1
    • Unplug the front facing camera press fit connector from the motherboard by prying upwards with a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photos could potentially damage your device.
  6. LG Fortune Rear Camera Replacement: шаг 6, изображение 1 из 1
    • Unplug the rear facing camera ribbon cable from the motherboard by prying up the press fit connector with a spudger.
    • Using a metal spudger as shown in the photos has the potential to damage your device. Choose an ESD safe tool instead.
  7. LG Fortune Rear Camera Replacement: шаг 7, изображение 1 из 1
    • Use the spudger to pry off the motherboard from the rest of the device on the top left corner down to the bottom right corner
  8. LG Fortune Rear Camera Replacement, Rear Camera: шаг 8, изображение 1 из 2 LG Fortune Rear Camera Replacement, Rear Camera: шаг 8, изображение 2 из 2
    • Unplug the camera from the phone using a metal spudger to get underneath the tape and remove the camera.
    • This will require a bit of force. Don't be afraid to apply the necessary amount to remove.
Заключение
Cori Johnson
Участник с: 04/08/19
531 Репутация
Автор 5 руководств
Команда
Eastern Washington University, Team S1-G5, Rowley Spring 2019 Участник Eastern Washington University, Team S1-G5, Rowley Spring 2019
EWU-ROWLEY-S19S1G5
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 10
За всё время: 231
