Введение
If your LG Fortune’s camera has begun degrade a little bit and is not taking pictures as well as it should, or has, then use this guide to replace your camera
Выберете то, что вам нужно
Use the slit on the bottom right side of the phone to open the back cover of your phone.
Slowly pry the back cover off the phone starting from the bottom up to the top.
Use the slot in the middle of the bottom edge of the battery to pry it up and out of the case.
Using a PH000 screwdriver, remove the ten 4mm screws on the back panelling.
Remove the back panelling from the device with your fingers or a spudger.
Work slowly side to side to release this back casing and expose the motherboard.
Unplug the video card from the motherboard with a spudger or plastic opening tool.
Unplug the front facing camera press fit connector from the motherboard by prying upwards with a spudger or plastic opening tool.
Unplug the rear facing camera ribbon cable from the motherboard by prying up the press fit connector with a spudger.
Use the spudger to pry off the motherboard from the rest of the device on the top left corner down to the bottom right corner
Unplug the camera from the phone using a metal spudger to get underneath the tape and remove the camera.
