LG G Pad 7.0 Battery Replacement
Выберете то, что вам нужно
  1. LG G Pad 7.0 Battery Replacement, Front Panel: шаг 1, изображение 1 из 2 LG G Pad 7.0 Battery Replacement, Front Panel: шаг 1, изображение 2 из 2
    • The screen assembly is secured to the plastic backing with clips. Insert the spudger between the screen and plastic.
    • Work your way around the device, freeing it from the connecting clips.
    • Be careful around the MicroSD, sim card, power, and volume buttons
    • Attempt to lift the tablet from the plastic frame. You may need to loosen some more clips if it is difficult to remove.
  2. LG G Pad 7.0 Battery Replacement, Battery Connector: шаг 2, изображение 1 из 3 LG G Pad 7.0 Battery Replacement, Battery Connector: шаг 2, изображение 2 из 3 LG G Pad 7.0 Battery Replacement, Battery Connector: шаг 2, изображение 3 из 3
    • Remove the battery connector marked in orange, by prying it upwards.You may need some force to do this, be careful not to damage anything.
    • Remove the other connector marked in red by gently prying up. Be sure not to rip the ribbon cables as they are very fragile.
  3. LG G Pad 7.0 Battery Replacement, Battery: шаг 3, изображение 1 из 1
    • Gently pry the battery up making sure not to bend it or snag any cables.
    • The battery is secured by two pieces of double sided tape on the left and right edges under the battery.
Заключение
18 участников успешно повторили данное руководство.
Ethan Chow
Участник с: 09/05/15
2 100 Репутация
Автор 3 руководств
Один комментарий
Thank you for this guide. The iFixit tool worked much better than the one that came with the replacement battery. I needed a magnifying glass to verify I lined up the ribbon cable connector but other than that it went smoothly.
Juan Campos - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 49
За всё время: 16,773
