LG G Pad 7.0 LTE Battery Replacement
Выберете то, что вам нужно
  1. LG G Pad 7.0 LTE Battery Replacement, Removing the Back Cover: шаг 1, изображение 1 из 1
    • Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
    • Be wary of the front screen and SIM Card while tearing down the device.
  2. LG G Pad 7.0 LTE Battery Replacement: шаг 2, изображение 1 из 1
    • Put on an Anti-Static Wrist Strap to prevent damage to sensitive electrical components (optional).
    • To separate the frame from the cover, pry between the screen and the cover using a plastic prying tool.
    • Begin at the top left of the device to avoid damaging the motherboard and work your way around the perimeter of the screen.
    • When you pry your device open, be wary of the volume rockers, motherboard, and camera. These components are delicate and can be sensitive to static electricity.
  3. LG G Pad 7.0 LTE Battery Replacement, Battery: шаг 3, изображение 1 из 1
    • Disconnect the battery connector by prying it upwards (blue marker).
    • Remove the ribbon cable by prying it upwards (red marker).
    • Do not bend the cable or connector as they are fragile.
  4. LG G Pad 7.0 LTE Battery Replacement: шаг 4, изображение 1 из 1
    • There is a light adhesive holding the battery in the frame of the device. Gently pry the bottom the battery using a plastic pry tool.
    • Be careful not to bend the battery as this may damage it.
Заключение
2 участников успешно повторили данное руководство.
Fadi Bitar
Участник с: 09/26/16
880 Репутация
Автор 6 руководств
Команда
USF Tampa, Team 14-6, Eyestone Fall 2016 Участник USF Tampa, Team 14-6, Eyestone Fall 2016
USFT-EYESTONE-F16S14G6
4 членов
Автор 12 руководств
4 Комментариев
This tells me how to take out the battery. Any little tricks I need to know to put in a new one?
John - Ответить
This is how I remove the battery. Any tricks to installing a new one?
John - Ответить
No trick, follow instruction in reverse substituting the new battery and you’ll be golden.
Michael Barreto - Ответить
Thanks so far, but when the back has been separated it does not look like yours. Can you enlighten me on how to remove the 2nd black plastic layer that covers the battery and circuit boards so I can access the battery? My email is atschramm1@outlook.com
ATS - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 5
За последние 30 дней: 24
За всё время: 2,875
