Введение
In cases where the battery is not charging or the device isn’t powering on, this guide will help you replace the battery to fix these issues.
Выберете то, что вам нужно
Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
To separate the frame from the cover, pry between the screen and the cover using a plastic prying tool.
Disconnect the battery connector by prying it upwards (blue marker).
Remove the ribbon cable by prying it upwards (red marker).
There is a light adhesive holding the battery in the frame of the device. Gently pry the bottom the battery using a plastic pry tool.
2 участников успешно повторили данное руководство.
4 Комментариев
No trick, follow instruction in reverse substituting the new battery and you’ll be golden.
