LG G Pad 7.0 LTE Front Facing Camera Replacement
Выберете то, что вам нужно
  1. LG G Pad 7.0 LTE Front Facing Camera Replacement, Removing the Back Cover: шаг 1, изображение 1 из 1
    • Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
    • Be wary of the front screen and SIM Card while tearing down the device.
    Спросите у FixBot
    Добавить комментарий
  2. LG G Pad 7.0 LTE Front Facing Camera Replacement: шаг 2, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Anti-Static Wrist Strap
    $7.95
    • Put on an Anti-Static Wrist Strap to prevent damage to sensitive electrical components (optional).
    • To separate the frame from the cover, pry between the screen and the cover using a plastic prying tool.
    • Begin at the top left of the device to avoid damaging the motherboard and work your way around the perimeter of the screen.
    • When you pry your device open, be wary of the volume rockers, motherboard, and camera. These components are delicate and can be sensitive to static electricity.
    Спросите у FixBot
  3. LG G Pad 7.0 LTE Front Facing Camera Replacement, Motherboard: шаг 3, изображение 1 из 1
    • Disconnect the battery connector by prying it upwards (red marker).
    • Be careful not to damage it while doing so.
    • Remove the ribbon cables by prying them upwards with a plastic pry tool ).
    • Do not bend the cable or connector as they are fragile.
    Спросите у FixBot
  4. LG G Pad 7.0 LTE Front Facing Camera Replacement: шаг 4, изображение 1 из 1
    • There is a light adhesive holding the camera in the device.
    • Using tweezers or a small plastic pry tool gently pull or pry the camera out of the device.
    Спросите у FixBot
  5. LG G Pad 7.0 LTE Front Facing Camera Replacement: шаг 5, изображение 1 из 1
    • Pry the audio jack from the device using a spudger.
    Спросите у FixBot
  6. LG G Pad 7.0 LTE Front Facing Camera Replacement: шаг 6, изображение 1 из 1
    • Remove the 7 Black 3mm PH0 screws from the motherboard (red markers).
    Спросите у FixBot
  7. LG G Pad 7.0 LTE Front Facing Camera Replacement: шаг 7, изображение 1 из 1
    • Remove the Motherboard.
    Спросите у FixBot
  8. LG G Pad 7.0 LTE Front Facing Camera Replacement, Front Facing Camera: шаг 8, изображение 1 из 1
    • Gently pull up on the camera to remove it.
    Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Fadi Bitar
Участник с: 09/26/16
880 Репутация
Автор 6 руководств
Команда
USF Tampa, Team 14-6, Eyestone Fall 2016 Участник USF Tampa, Team 14-6, Eyestone Fall 2016
USFT-EYESTONE-F16S14G6
4 членов
Автор 12 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 6
За последние 30 дней: 44
За всё время: 508
