Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the MicroSD Memory card, Sim Card, and the metal Sim Card Holder.
Put them off to the side for reassembly.
Now you can slowly use a plastic opening tool to go around the edge of the tablet to slowly pry upward.
Now that we have the back cover and can remove the orange port strip.
Use the spudger to gently remove the strip by pushing upward slowly.
To disconnect the battery you are going to unplug the cables.
Use the tweezers to gently hold the cables and slowly push upward to detach it.
Don't be too rough and pinch the cables with the tweezers. Take your time and slowly detach.
Remove the 7 black screws on the motherboard.
Put them to the side for reassembly.
Detach the black tag in the middle of the motherboard. This is the main camera connection.
Locate the next camera connection at the top of the motherboard. Disconnect this black tag for your front camera.
Now you are able to remove the motherboard from the tablet.
Now that the motherboard is removed, you can now access the main camera for removal. Gently use the tweezers to do this.
Put to the side for reassembly.
Using the Phillips screwdriver, remove the screw and put aside for reassembly.
Two screws are holding the metal plate down. Remove the screws and put aside.
Use the tweezers to remove the tape to show the connection.
Use the spudger to push up and remove the connection.
Use the tweezers to completely remove charging port from tablet. Put aside for reassembly.
To remove the battery, use the spudger or the Jimmy tool to slowly work your way around the battery.
It is being held on by strips of tape so be patient with it. Work it a little bit at a time to remove the battery from the tablet.
Put it aside for reassembly.
Apply a heat gun or iOpener to front of screen to allow it to warm up the glue.
Use opening tool and work your way around the front of the screen. You may have to alternate applying the heat and prying to get it loose enough to separate.
Be careful not overdo the heat. Use a low temperature and take your time to separate the screen.
Clean the black backing off of any glass still sticking to it. Mine had a lot so I had to scrape for awhile to get all the little pieces off to have a clean surface to apply the new replacement screen.
Apply new screen to black backing.
38 участников успешно повторили данное руководство.
18 Комментариев
Great help..........thanks
Good job but I have just 1 speaker out.
Do you mean you took one speaker out or the speaker is no longer functioning properly?
Hello Ms. Heather I cannot access the motherboard, I am unable to remove the back cover. Pls help
Are you using a prying tool and going around the edges of the tablet to open it? What exactly is happening?
