Выберете то, что вам нужно
Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
To separate the frame from the cover, pry between the screen and the cover using a plastic prying tool.
Disconnect the battery connector by prying it upwards (red marker).
Remove the ribbon cables by prying them upwards with a plastic pry tool ).
2 участников успешно повторили данное руководство.
