LG G Pad 7.0 Motherboard Replacement
Выберете то, что вам нужно
  1. LG G Pad 7.0 Motherboard Replacement, Front Panel: шаг 1, изображение 1 из 2 LG G Pad 7.0 Motherboard Replacement, Front Panel: шаг 1, изображение 2 из 2
    • The screen assembly is secured to the plastic backing with clips.Insert the plastic opening tool between the screen and plastic.
    • Carefully work your way around the device making sure not to go too deep damaging any eternal components, freeing it from the connecting clips.
    • Be careful around the MicroSD, sim card, power, and volume buttons
    • Lift the tablet from the plastic frame. You may need to loosen some more clips if it is difficult to remove.
  2. LG G Pad 7.0 Motherboard Replacement, Connectors: шаг 2, изображение 1 из 3 LG G Pad 7.0 Motherboard Replacement, Connectors: шаг 2, изображение 2 из 3 LG G Pad 7.0 Motherboard Replacement, Connectors: шаг 2, изображение 3 из 3
    • Remove the red marked connectors by gently prying up. Be sure not to rip the ribbon cables as they are very fragile.
    • You will have to remove the metallic tape near the bottom of the tablet to disconnect the display cable.
    • Remove the three connectors marked in orange by gently prying them upwards. The cables are very fragile so be careful not to rip them.
  3. LG G Pad 7.0 Motherboard Replacement, Logic Board: шаг 3, изображение 1 из 2 LG G Pad 7.0 Motherboard Replacement, Logic Board: шаг 3, изображение 2 из 2
    • Remove the 7 screws marked in red that are securing the logic board to the case.
    • Be sure that all the connectors marked in orange are removed before pulling out the mother board.
    • Very carefully remove the logic board after the screws have been removed
  4. LG G Pad 7.0 Motherboard Replacement: шаг 4, изображение 1 из 3 LG G Pad 7.0 Motherboard Replacement: шаг 4, изображение 2 из 3 LG G Pad 7.0 Motherboard Replacement: шаг 4, изображение 3 из 3
    • Remove the two screw marked in red.
    • Using the tweezers , gently pull out the metal bracket that holds the charging port in place.
    • Carefully pull out the ribbon connector in orange.
    • Remove the one screw that holds the speaker in place.
    • Slowly pull out the speaker.
  5. LG G Pad 7.0 Motherboard Replacement: шаг 5, изображение 1 из 2 LG G Pad 7.0 Motherboard Replacement: шаг 5, изображение 2 из 2
    • Insert your new mother board with the 7 screws
    • Reconnect all the connectors marked in red back to the mother board.
Заключение
3 участников успешно повторили данное руководство.
echow2001
Участник с: 09/05/15
2 117 Репутация
Автор 4 руководств
Команда
LGBTQ Technicians Участник LGBTQ Technicians
Community
14 членов
Автор 23 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 2,047
