Введение
To replace your back camera, you can use this one simple replacement guide.
Выберете то, что вам нужно
With the screen faced up, insert the metal spudger into the crevice so that it is sticking out between the side panel and the screen.
Take the spudger and slide it around the perimeter of the device.
Pull gently on the edges to get the panel to pop up.
Insert spudger to the right edge of the gold band and gently pry it up to disconnect the chip.
Repeat step with top and bottom sides.
Remove with tweezers.
