Выберете то, что вам нужно
With the screen faced up, insert the metal spudger into the crevice so that it is sticking out between the side panel and the screen.
Take the spudger and slide it around the perimeter of the device.
Pull gently on the edges to get the panel to pop up.
Put the spudger underneath the gold cap of the cable and lift to disconnect from device.
Place the spudger in between the speaker and the device to pop the speaker out of place.
Pull the speaker out of the device.
Один комментарий
I have followed your guide (LG G Pad 8.3 4G Battery Replacement) but what see when I pry off the screen is not what is on your pic of step 2.
It appears that I have to pry off the back panel to actually see the battery, the speakers and the gold cable.
How can I pry off the back panel?
Thanks,
Ed
