Введение
If your LG G Pad 8.3 speaker isn't working, it may be time to replace it. This guide will show you how to replace the speaker.
Выберете то, что вам нужно
With the tablet face down, pull the SD card slot cover out.
Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
Insert a plastic opening tool in the small crevasse between the screen and the back panel.
Pry the screen away from the back panel.
Repeat this on each edge of the device.
After using the plastic opening tools, pry the device open with your hands.
Remove the back panel from the screen.
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
4 участников успешно повторили данное руководство.
