LG G Pad F 7.0 Motherboard Replacement
Выберете то, что вам нужно
  1. LG G Pad F 7.0 Motherboard Replacement, Rear Camera: шаг 1, изображение 1 из 2 LG G Pad F 7.0 Motherboard Replacement, Rear Camera: шаг 1, изображение 2 из 2
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out
    • Remove SIM card and set aside
  2. LG G Pad F 7.0 Motherboard Replacement: шаг 2, изображение 1 из 1
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Motherboard Replacement: шаг 3, изображение 1 из 2 LG G Pad F 7.0 Motherboard Replacement: шаг 3, изображение 2 из 2
    • Use the plastic opening tool to pry up the ribbon cable connecting to the camera unit.
    • One the ribbon cable has been detached, use the tweezers to pull up the camera. It is attached with adhesive so pull up gently to remove it.
    • Once the old camera unit is removed, replace with new unit and reassemble in reverse order of guide.
  4. LG G Pad F 7.0 Motherboard Replacement, Motherboard: шаг 4, изображение 1 из 1
    • Locate the large orange ribbon cable, pry off the side shown in the image.
  5. LG G Pad F 7.0 Motherboard Replacement: шаг 5, изображение 1 из 2 LG G Pad F 7.0 Motherboard Replacement: шаг 5, изображение 2 из 2
    • Use the plastic opening tool to pry the multicolor wire cables off, applying force up away from the tablet.
    • Use the plastic opening tool to pry up the battery. There is adhesive underneath the battery, so use a small amount of force. Work your way around the edge of the battery to pry it off.
  6. LG G Pad F 7.0 Motherboard Replacement: шаг 6, изображение 1 из 2 LG G Pad F 7.0 Motherboard Replacement: шаг 6, изображение 2 из 2
    • Locate the front facing camera ribbon cable attachment on the motherboard
    • Leave the ribbon cable disconnected.
  7. LG G Pad F 7.0 Motherboard Replacement: шаг 7, изображение 1 из 2 LG G Pad F 7.0 Motherboard Replacement: шаг 7, изображение 2 из 2
    • Locate the six Phillips head screws on the LG G Pad F 7.0 Motherboard
    • Use Phillips #0 Screwdriver to unscrew the six screws.
  8. LG G Pad F 7.0 Motherboard Replacement: шаг 8, изображение 1 из 2 LG G Pad F 7.0 Motherboard Replacement: шаг 8, изображение 2 из 2
    • Remove the motherboard by prying it out with the plastic opening tool (as shown in image).
Заключение
2 участников успешно повторили данное руководство.
Jose Hurtado
Участник с: 01/25/17
329 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 8-5, Banghart Winter 2017 Участник Cal Poly, Team 8-5, Banghart Winter 2017
CPSU-BANGHART-W17S8G5
3 членов
Автор 10 руководств
Один комментарий
Some spelling errors but overall simple to follow
Jonah Basl - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 522
