LG G Pad X 8.3 Battery Replacement
Выберете то, что вам нужно
  1. LG G Pad X 8.3 Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Remove the cover of the SD card. Find it on the right side of the back of the tablet.
    • Press the SD card in to make it pop out.
  2. LG G Pad X 8.3 Battery Replacement: шаг 2, изображение 1 из 1
    • Slide the stylus out from the bottom left corner of the back panel.
  3. LG G Pad X 8.3 Battery Replacement: шаг 3, изображение 1 из 1
    • Start at a corner and pry the screen up with a plastic opening tool.
    • You can also use a plastic spudger for this task, but do not use metal tools. They can be dangerous to you and the device.
    • Slide the tool in the seam at the edge of the screen.
    • Wedge additional plastic opening tools in the seam to help lift the screen.
    • Slide both wedged plastic opening tools towards the bottom to pop the screen loose.
    • If your screen is cracked, work slowly to avoid flinging glass shards when prying.
  4. LG G Pad X 8.3 Battery Replacement: шаг 4, изображение 1 из 3 LG G Pad X 8.3 Battery Replacement: шаг 4, изображение 2 из 3 LG G Pad X 8.3 Battery Replacement: шаг 4, изображение 3 из 3
    • With a Phillips #000 screwdriver, unscrew the six 4.0 mm screws that hold down the battery.
    • With the Phillips #000 screwdriver, unscrew the two 4.0 mm screws that hold down the battery ribbon connector.
    • Use a magnetic mat to keep track of these tiny screws for later reassembly.
  5. LG G Pad X 8.3 Battery Replacement: шаг 5, изображение 1 из 1
    • Lift the battery ribbon connector with your finger.
  6. LG G Pad X 8.3 Battery Replacement: шаг 6, изображение 1 из 1
    • Lift the battery with your fingers and remove it from the device.
Заключение
Еще один человек закончил это руководство.
Roxanne McPeck
Участник с: 04/09/18
345 Репутация
1 руководство автора
Команда
Eastern Washington University, Team S3-G4, Rowley Spring 2018 Участник Eastern Washington University, Team S3-G4, Rowley Spring 2018
EWU-ROWLEY-S18S3G4
4 членов
Автор 10 руководств
2 Комментариев
This looks to be a helpful Guide, but there is no help in WHERE to purchase a battery and if there could be a different battery with higher capacity and a longer life as a choice. As a Consumer, this type of information would be helpful.
Harvey Rothenberg - Ответить
I cannot get a wedge tool in to remove the screen on my LG G Pad X 10.1. Any suggestions?
Hillary Brandeberry - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 5,299
