LG G Stylo Front Camera Replacement
Выберете то, что вам нужно
  1. LG G Stylo Front Camera Replacement, Battery: шаг 1, изображение 1 из 2 LG G Stylo Front Camera Replacement, Battery: шаг 1, изображение 2 из 2
    • Make sure that you power off the phone before beginning.
    • Remove the back cover by placing the plastic opening tool on the bottom left side of the device and gently prying up.
    • There is a small slit that fits the plastic opening tool perfectly on the left side.
  2. LG G Stylo Front Camera Replacement: шаг 2, изображение 1 из 2 LG G Stylo Front Camera Replacement: шаг 2, изображение 2 из 2
    • Insert the plastic opening tool into the indent at the bottom of the battery and lift up. Fully remove the battery with your fingers.
  3. LG G Stylo Front Camera Replacement, Motherboard: шаг 3, изображение 1 из 2 LG G Stylo Front Camera Replacement, Motherboard: шаг 3, изображение 2 из 2
    • Carefully use the Phillips #00 screwdriver to remove the eleven 3.9mm visible screws found on the back. The screws to be removed are marked with the given indicators.
  4. LG G Stylo Front Camera Replacement: шаг 4, изображение 1 из 3 LG G Stylo Front Camera Replacement: шаг 4, изображение 2 из 3 LG G Stylo Front Camera Replacement: шаг 4, изображение 3 из 3
    • When you have finished removing all of the screws, place the plastic opening tool in the groove at the bottom left corner of the motherboard cover and lift up.
    • Make sure to remove the SIM card before you remove the motherboard cover. You can get the cover off without doing this, but the SIM card will be stuck underneath the cover once you put it back together.
    • This part could be more difficult if you have never removed the motherboard cover. If difficulty arises, pry the plastic opening tool into each groove along the edge of the motherboard cover until it releases.
    • Once a clip is released, you can detach the motherboard cover with your fingers and set aside.
  5. LG G Stylo Front Camera Replacement: шаг 5, изображение 1 из 3 LG G Stylo Front Camera Replacement: шаг 5, изображение 2 из 3 LG G Stylo Front Camera Replacement: шаг 5, изображение 3 из 3
    • Carefully place the plastic opening tool under the ribbons where the cables are connecting and lift up to detach the cables.
    • Keep in mind to be careful with the ribbons, because they are small components and important for the device's functionality.
    • The third photo attached depicts what the ribbons look like when they are successfully detached.
  6. LG G Stylo Front Camera Replacement: шаг 6, изображение 1 из 2 LG G Stylo Front Camera Replacement: шаг 6, изображение 2 из 2
    • Fully remove the motherboard by prying upward with the plastic opening tool.
    • This step will be quite simple if all the ribbons have been detached correctly.
  7. LG G Stylo Front Camera Replacement, Front Camera: шаг 7, изображение 1 из 3 LG G Stylo Front Camera Replacement, Front Camera: шаг 7, изображение 2 из 3 LG G Stylo Front Camera Replacement, Front Camera: шаг 7, изображение 3 из 3
    • Indicated on the back of the phone is the front camera. To remove the front camera, detach the ribbon cable located on the back of the phone at the top-left.
    • Gently lift up the ribbon with the plastic opening tool. Remove the front camera and replace accordingly.
    • Be careful when removing to avoid harming the device and tearing the attached ribbon.
Заключение
Еще один человек закончил это руководство.
Douglas Schmidt
Участник с: 02/09/16
422 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 11-7, Cheng Spring 2016 Участник USF Tampa, Team 11-7, Cheng Spring 2016
USFT-CHENG-S16S11G7
4 членов
Автор 14 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 11
За последние 30 дней: 15
За всё время: 1,126
