Введение
This guide will help you replace the micro SD card in your LG G Vista phone. This is a relatively easy process, and you shouldn't need anything other than your fingers.
Using your fingers or a plastic opening tool, remove the back cover from the device.
Using your fingers or a plastic opening tool, eject the micro SD card from the device.
Еще один человек закончил это руководство.
