LG G Watch Motherboard Replacement
Выберете то, что вам нужно
  1. LG G Watch Motherboard Replacement, Wristband: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
  2. LG G Watch Motherboard Replacement: шаг 2, изображение 1 из 2 LG G Watch Motherboard Replacement: шаг 2, изображение 2 из 2
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
  3. LG G Watch Motherboard Replacement, Rear Case: шаг 3, изображение 1 из 1
    • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
  4. LG G Watch Motherboard Replacement: шаг 4, изображение 1 из 2 LG G Watch Motherboard Replacement: шаг 4, изображение 2 из 2
    • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
    • Gently pull the two halves apart.
  5. LG G Watch Motherboard Replacement, Gasket: шаг 5, изображение 1 из 1
    • Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
  6. LG G Watch Motherboard Replacement, Motherboard: шаг 6, изображение 1 из 2 LG G Watch Motherboard Replacement, Motherboard: шаг 6, изображение 2 из 2
    • Use the spudger to gently lift up and disconnect the display connector.
    • Now use the spudger to disconnect the digitizer connector.
  7. LG G Watch Motherboard Replacement: шаг 7, изображение 1 из 2 LG G Watch Motherboard Replacement: шаг 7, изображение 2 из 2
    • Use a Phillips #000 screwdriver to remove the two black PHO 2.5mm x 3mm screws.
    • Use the spudger to gently remove the motherboard.
Заключение
4 человек успешно провели ремонт по этому руководству.
Meles Anneaud
Участник с: 09/23/14
140 Репутация
1 руководство автора
Команда
USF Tampa, Team 2-5, Blackwell Fall 2014 Участник USF Tampa, Team 2-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G5
5 членов
Автор 9 руководств
1 Комментарий к руководству
is it possible to replace the battery which is in the board?
Vassago U7 (VassagoU7) - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 49
За всё время: 1,303
