Введение
This guide will show you how to replace the motherboard in your LG G Watch.
Выберете то, что вам нужно
First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
Grasp the exposed shoulder with the tweezers to perform the next step.
Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
Slide the opening pick between the rear case and the rest of the device to separate the two halves.
Gently pull the two halves apart.
Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
Use the spudger to gently lift up and disconnect the display connector.
Now use the spudger to disconnect the digitizer connector.
Use a Phillips #000 screwdriver to remove the two black PHO 2.5mm x 3mm screws.
Use the spudger to gently remove the motherboard.
4 участников успешно повторили данное руководство.
Один комментарий
is it possible to replace the battery which is in the board?
Is there a reason you are removing the straps before the back of the watch? They don't block the back from coming off or really get in the way much.
Andy Wickham - Ответить
its in the way, obviously it need to take them off, lol.
silentg4real -
Where can I get this battery?
Josh Wheat - Ответить
where can i buy a new replacement rear case? please let me know!
silentg4real - Ответить
I'd like to know as well and don't care if it's a knock off either
Joseph Wellman -
