Введение
In addition to protecting the internal components of the watch, the back case also fastens the power charging conductor and heart rate monitor to the watch's motherboard.
Инструменты
Запчасти
Детали не указаны.
Place the watch upside down on a hard surface so that its back case is facing upright.
Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
Use a plastic opening tool to pry open the back case from both sides of the watch.
Еще один человек закончил это руководство.
