LG G Watch R Battery Replacement Replacement
Выберете то, что вам нужно
  1. LG G Watch R Battery Replacement Replacement, Back Case: шаг 1, изображение 1 из 2 LG G Watch R Battery Replacement Replacement, Back Case: шаг 1, изображение 2 из 2
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
    So i bought a torx t5…but it is tooo big. It must br torx t4
    Jetze Kooistra - Ответить
    I think I have damaged one of the screw heads while trying to unscrew the back of the watch.
    I used the Torx T4… but the screw was covered in quite a bit of rust. Now the Torx T4 can’t get a grip.
    What should I do? (Can anything be done?)
    John Maher - Ответить
    Yea take a tiny file or a tiny Dremel attachment and carve a flat head groove in the head just enough so where you can use a flat head to get it
    Andrew L rambeaut -
    Thank you for good instructions! Saved me for 300€ (don’t have to buy a new wacth) ?
    Ernst Kranke - Ответить
  2. LG G Watch R Battery Replacement Replacement: шаг 2, изображение 1 из 1
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Battery Replacement Replacement: шаг 3, изображение 1 из 1
    • Remove the back case.
  4. LG G Watch R Battery Replacement Replacement, Motherboard: шаг 4, изображение 1 из 2 LG G Watch R Battery Replacement Replacement, Motherboard: шаг 4, изображение 2 из 2
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
    Where do I buy the parts? I already have your tools.
    Marco Roman - Ответить
  5. LG G Watch R Battery Replacement Replacement: шаг 5, изображение 1 из 2 LG G Watch R Battery Replacement Replacement: шаг 5, изображение 2 из 2
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
    Add colored markup to indicate location of the 3 screws.
    Patty Remmell - Ответить
    I felt like my #00 driver fit slightly better for these screws, but it probably depends on which toolkit or bit set you have.
    J Suo - Ответить
  6. LG G Watch R Battery Replacement Replacement: шаг 6, изображение 1 из 1
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
  7. LG G Watch R Battery Replacement Replacement, Battery Replacement: шаг 7, изображение 1 из 1
    • Use a plastic opening tool to pry the battery out of the device.
    • You may need to use a stronger prying force due to the adhesive that secures the battery to the case.
Заключение
70 участников успешно повторили данное руководство.
Westley Courchene
Участник с: 01/13/15
3 341 Репутация
Автор 14 руководств
Команда
USF Tampa, Team 1-1, Remmell Fall 2015 Участник USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 членов
Автор 14 руководств
12 Комментариев
It did help, small correction - Use a T4 instead of T5 screw driver
Suyog Patki - Ответить
On my G Watch R the T5 screw driver perfektly fits.
igor-sweet -
I second the fonejoy link, got it delivered from them very quickly. And I also second what Suyog said regarding the Torx screwdriver, on my own watch I needed a T4, the T5 didn't work, but I had a set so I was okay.
Mike - Ответить
Perfekt Instruktion only the estimated time of 5 minutes ist very ambigous lol. Thanks a lot
Martin Becker - Ответить
Did you guys retain water resistance after the battery swap?
Viktor Nemeth - Ответить
There is an o-ring type seal connected to the backplate. As long as you are careful when taking the backplate off and also make sure that the channel this fits into when you re-assemble is clean, you should be OK. It’s only about 1mm from the edge of the backplate, so don’t dig too deep with your loosening tool when taking the plate off.
Andy Wray -
The above instructions worked fine for me as someone who has never done anything like this before … watch is now back to being fully-operational with the latest version of android wear and great battery life. I too used fonejoy .. delivery within 24 hours :) I’d never tried re-connecting this type of PCB connector before and fiddled around for some time before realising that they click into place quite easily. This is probably a 30 minutes job for most of us rather than 5 minutes.
Andy Wray - Ответить
Where can I get the battery.. Cos am in Benin
Daniel Danjeezy - Ответить
Works perfectly, with one remark. The original spare LG battery I ordered had a slightly different shape. in order to make it fit I had to push the new battery upwards, not center it (intuitively done)
great guide!
Kasper Jordaens - Ответить
I am very happy with this instruction. LG watch R is one of the best supported devices for AsteroidOS.
https://petergamma.org/page-2/
herefore it is very important that the battery can be replaced. Many thanks for the instruction.
Peter Gamma - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 17
За последние 30 дней: 106
За всё время: 29,008
