Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Place the watch upside down on a hard surface so that its back case is facing upright.
Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
Use a plastic opening tool to pry open the back case from both sides of the watch.
With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
3 участников успешно повторили данное руководство.
3 Комментариев
Where do I buy a replacement motherboard from??
Did you ever find anywhere to order a replacement motherboard?
