Введение
Removing the power button might be useful when attempting to clean the device.
Выберете то, что вам нужно
Place the watch upside down on a hard surface so that its back case is facing upright.
Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
Use a plastic opening tool to pry open the back case from both sides of the watch.
With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
Use a plastic opening tool to pry the battery out of the device.
Pry the battery housing from the top right corner using a spudger.
Once loosened, remove the battery housing.
On the power button, locate a small grey washer on the interior side of the watch.
Use a pair of tweezers or another pointed object to push the washer out of its socket, and remove the power button.
7 участников успешно повторили данное руководство.
