Введение
If the buckle or part of the wristband is damaged, it is a good idea to replace the bands on both sides so that they match.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Tweezers$4.99
First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
Grasp the exposed shoulder with the tweezers to perform the next step.
Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
Еще один человек закончил это руководство.
