LG G2 Sprint Display Assembly Replacement
Выберете то, что вам нужно
  1. LG G2 Sprint Display Assembly Replacement, Charger Port: шаг 1, изображение 1 из 2 LG G2 Sprint Display Assembly Replacement, Charger Port: шаг 1, изображение 2 из 2
    • Use a plastic opening tool to pry open your phone case. Flip the phone over and start by sliding your tool between the two sides of your phone case. Work the tool towards the bottom of the phone case, gently prying the case open. There is a clip that will pop open after applying gentle but consistent pressure.
    • Make sure to release the clip on the top left corner of the phone case carefully. This is usually the most difficult clip to release.
  2. LG G2 Sprint Display Assembly Replacement: шаг 2, изображение 1 из 1
    • After removing the outer phone case, you will need two Phillips head bits. One J0 and one J000 size.
    • There are 11 silver screws for which you have to use J0 head bits, and 1 small black screw for which you have to use a J000 head bit.
  3. LG G2 Sprint Display Assembly Replacement: шаг 3, изображение 1 из 3 LG G2 Sprint Display Assembly Replacement: шаг 3, изображение 2 из 3 LG G2 Sprint Display Assembly Replacement: шаг 3, изображение 3 из 3
    • There is a clip on the upper left side of the upper panel. Use the plastic opening tool to pry the clip off of the phone.
    • The upper inside panel flips up easily off of the phone case once all the clips and screws are removed. If the panel does not pull off easily, check that you have removed all of the screws.
    • There are ribbons that need to be removed as well. Be sure to carefully pry them off of the board
  4. LG G2 Sprint Display Assembly Replacement: шаг 4, изображение 1 из 3 LG G2 Sprint Display Assembly Replacement: шаг 4, изображение 2 из 3 LG G2 Sprint Display Assembly Replacement: шаг 4, изображение 3 из 3
    • The bottom inside panel should pry back easily after you take out the screws. Again, if the panel does not pull off easily, you may have missed a screw.
  5. LG G2 Sprint Display Assembly Replacement: шаг 5, изображение 1 из 3 LG G2 Sprint Display Assembly Replacement: шаг 5, изображение 2 из 3 LG G2 Sprint Display Assembly Replacement: шаг 5, изображение 3 из 3
    • There are several clips and circuits that need to be released. They are circled in the images above. Be careful not to break any of the attached ribbon or wires. (circle ribbons etc.)
    • Be careful to use your tools to disconnect the cables at the connectors and not along the wire.
  6. LG G2 Sprint Display Assembly Replacement: шаг 6, изображение 1 из 3 LG G2 Sprint Display Assembly Replacement: шаг 6, изображение 2 из 3 LG G2 Sprint Display Assembly Replacement: шаг 6, изображение 3 из 3
    • The orange materials is meant to bend along the dotted line labeled “bend.” Try to make the bend as close to this line as possible.
  7. LG G2 Sprint Display Assembly Replacement: шаг 7, изображение 1 из 3 LG G2 Sprint Display Assembly Replacement: шаг 7, изображение 2 из 3 LG G2 Sprint Display Assembly Replacement: шаг 7, изображение 3 из 3
    • After you have disconnected all of the ribbon and antennae connections, you can remove the board. Gently pry the board up from the bottom of the case and slide it back out.
    • Make sure to remove all ribbon connectors from the board prior to removing the board.
  8. LG G2 Sprint Display Assembly Replacement, Display Assembly: шаг 8, изображение 1 из 2 LG G2 Sprint Display Assembly Replacement, Display Assembly: шаг 8, изображение 2 из 2
    • Now you are ready to remove the battery. Make sure to adhere to ESD prevention guidelines, use a plastic tool as to not damage the battery.
    • Start at the top left of the battery and slide your nylon spudger under the battery. There is a layer of adhesive that keeps the battery in the case. Use steady, firm pressure to pull the battery up.
    • If the battery case begins to bend, you may need to use less force.
  9. LG G2 Sprint Display Assembly Replacement: шаг 9, изображение 1 из 3 LG G2 Sprint Display Assembly Replacement: шаг 9, изображение 2 из 3 LG G2 Sprint Display Assembly Replacement: шаг 9, изображение 3 из 3
    • Removed the cables by pulling them out, they are held in by black tape.
    • The vibe motor is held in by a strong adhesive, use a slim tool to get underneath and remove.
    • The camera can be removed effortlessly by using a slim plastic tool to lift it out of the assembly, start under the ribbon cable to pry out.
    • All components should be removed with ESD safe tools.
  10. LG G2 Sprint Display Assembly Replacement: шаг 10, изображение 1 из 1
    • Once all components have been removed the display assembly with be the only part left, the final step is to replace this part.
Заключение
5 человек успешно провели ремонт по этому руководству.
Ryan Bajnath
Участник с: 10/06/16
260 Репутация
1 руководство автора
Команда
USF Tampa, Team 5-2, Lacy Fall 2016 Участник USF Tampa, Team 5-2, Lacy Fall 2016
USFT-LACY-F16S5G2
4 членов
Автор 10 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 1,499
