LG G3 Motherboard Cover Assembly Replacement
Выберете то, что вам нужно
  1. LG G3 Motherboard Cover Assembly Replacement, Back Cover: шаг 1, изображение 1 из 2 LG G3 Motherboard Cover Assembly Replacement, Back Cover: шаг 1, изображение 2 из 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Motherboard Cover Assembly Replacement: шаг 2, изображение 1 из 2 LG G3 Motherboard Cover Assembly Replacement: шаг 2, изображение 2 из 2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Motherboard Cover Assembly Replacement, Battery: шаг 3, изображение 1 из 2 LG G3 Motherboard Cover Assembly Replacement, Battery: шаг 3, изображение 2 из 2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Motherboard Cover Assembly Replacement: шаг 4, изображение 1 из 2 LG G3 Motherboard Cover Assembly Replacement: шаг 4, изображение 2 из 2
    • Lift the battery out of its recess and remove it.
  5. LG G3 Motherboard Cover Assembly Replacement, Loudspeaker: шаг 5, изображение 1 из 1
    • Remove the four Phillips #00 screws (4 mm length).
  6. LG G3 Motherboard Cover Assembly Replacement: шаг 6, изображение 1 из 2 LG G3 Motherboard Cover Assembly Replacement: шаг 6, изображение 2 из 2
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
  7. LG G3 Motherboard Cover Assembly Replacement: шаг 7, изображение 1 из 3 LG G3 Motherboard Cover Assembly Replacement: шаг 7, изображение 2 из 3 LG G3 Motherboard Cover Assembly Replacement: шаг 7, изображение 3 из 3
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
  8. LG G3 Motherboard Cover Assembly Replacement, Motherboard Cover Assembly: шаг 8, изображение 1 из 1
    • Remove the eight Phillips #00 screws (4 mm length).
  9. LG G3 Motherboard Cover Assembly Replacement: шаг 9, изображение 1 из 3 LG G3 Motherboard Cover Assembly Replacement: шаг 9, изображение 2 из 3 LG G3 Motherboard Cover Assembly Replacement: шаг 9, изображение 3 из 3
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Work your way along the right edge.
  10. LG G3 Motherboard Cover Assembly Replacement: шаг 10, изображение 1 из 3 LG G3 Motherboard Cover Assembly Replacement: шаг 10, изображение 2 из 3 LG G3 Motherboard Cover Assembly Replacement: шаг 10, изображение 3 из 3
    • Carefully lift the right edge of the motherboard cover.
    • The remaining plastic clips should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Dominik Schnabelrauch
Участник с: 11/23/16
203 139 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 767 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 520
