LG G3 Rear Facing Camera Lens Cover Replacement
Выберете то, что вам нужно
Видео обзор
  1. LG G3 Rear Facing Camera Lens Cover Replacement, The damage: шаг 1, изображение 1 из 2 LG G3 Rear Facing Camera Lens Cover Replacement, The damage: шаг 1, изображение 2 из 2
    • A nice big rugged case is all good and well but it can't protect everything
  2. LG G3 Rear Facing Camera Lens Cover Replacement, Remove the battery cover: шаг 2, изображение 1 из 3 LG G3 Rear Facing Camera Lens Cover Replacement, Remove the battery cover: шаг 2, изображение 2 из 3 LG G3 Rear Facing Camera Lens Cover Replacement, Remove the battery cover: шаг 2, изображение 3 из 3
    • Locate the niche on the bottom right side of the phone.
    • You can use your finger nail or a pry tool to pop open the battery cover.
    • It is clipped on all around the phone. It shouldn't take too much force to open. It's quite easy to remove.
  3. LG G3 Rear Facing Camera Lens Cover Replacement, Remove camera lens cover: шаг 3, изображение 1 из 3 LG G3 Rear Facing Camera Lens Cover Replacement, Remove camera lens cover: шаг 3, изображение 2 из 3 LG G3 Rear Facing Camera Lens Cover Replacement, Remove camera lens cover: шаг 3, изображение 3 из 3
    • Remove the two screws holding the camera lens cover on. Keep in mind they are two different sizes. Short one up top, longer one on bottom. Use a small phillips head screwdriver. (sorry for removing them before taking the pic)
    • Remove the camera lens cover. I used my sharp pointed tweezers to pop the bottom of the cover up. It is also held in with small clips, much like the battery cover.
    • Save the volume/power button from the old cover and reuse it with the new camera lens cover.
  4. LG G3 Rear Facing Camera Lens Cover Replacement, Put new camera cover in: шаг 4, изображение 1 из 2 LG G3 Rear Facing Camera Lens Cover Replacement, Put new camera cover in: шаг 4, изображение 2 из 2
    • Clean the camera lens and the new camera lens cover. Put the new cover in. I put the left side in at an angle first and then popped the right side in to the clips. Don't use too much force or it could possibly break the plastic
    • Put the battery cover back on and slap your phone back in it's case if you have one. Done!
Заключение
20 участников успешно повторили данное руководство.
Bohemian
Участник с: 12/14/14
601 Репутация
1 руководство автора
9 Комментариев
This guide gave me the push to fix my lens cap issue myself. Ordered replacement parts off ebay from china for real cheap and it took me all of five minutes to replace the lens cap. now my pictures turn out great and I know how to fix this minor issue. Thanks!
Billy - Ответить
That's great to hear Billy. This phone is quite easy to fix. I might post another guide on it soon
Bohemian - Ответить
I purchased mine from amazon
Bohemian - Ответить
Excellent step by step. It is so simple yet without the confidence to even attempt to take the phone apart I would have not known. Thank you sir!
jasonstovall - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 28,991
