LG G3 Rear Facing Camera Replacement
Выберете то, что вам нужно
  1. LG G3 Rear Facing Camera Replacement, Back Cover: шаг 1, изображение 1 из 2 LG G3 Rear Facing Camera Replacement, Back Cover: шаг 1, изображение 2 из 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Rear Facing Camera Replacement: шаг 2, изображение 1 из 2 LG G3 Rear Facing Camera Replacement: шаг 2, изображение 2 из 2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Rear Facing Camera Replacement, Battery: шаг 3, изображение 1 из 2 LG G3 Rear Facing Camera Replacement, Battery: шаг 3, изображение 2 из 2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Rear Facing Camera Replacement: шаг 4, изображение 1 из 2 LG G3 Rear Facing Camera Replacement: шаг 4, изображение 2 из 2
    • Lift the battery out of its recess and remove it.
  5. LG G3 Rear Facing Camera Replacement, Loudspeaker: шаг 5, изображение 1 из 1
    • Remove the four Phillips #00 screws (4 mm length).
  6. LG G3 Rear Facing Camera Replacement: шаг 6, изображение 1 из 2 LG G3 Rear Facing Camera Replacement: шаг 6, изображение 2 из 2
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
  7. LG G3 Rear Facing Camera Replacement: шаг 7, изображение 1 из 3 LG G3 Rear Facing Camera Replacement: шаг 7, изображение 2 из 3 LG G3 Rear Facing Camera Replacement: шаг 7, изображение 3 из 3
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
  8. LG G3 Rear Facing Camera Replacement, Motherboard Cover Assembly: шаг 8, изображение 1 из 1
    • Remove the eight Phillips #00 screws (4 mm length).
  9. LG G3 Rear Facing Camera Replacement: шаг 9, изображение 1 из 3 LG G3 Rear Facing Camera Replacement: шаг 9, изображение 2 из 3 LG G3 Rear Facing Camera Replacement: шаг 9, изображение 3 из 3
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Work your way along the right edge.
  10. LG G3 Rear Facing Camera Replacement: шаг 10, изображение 1 из 3 LG G3 Rear Facing Camera Replacement: шаг 10, изображение 2 из 3 LG G3 Rear Facing Camera Replacement: шаг 10, изображение 3 из 3
    • Carefully lift the right edge of the motherboard cover.
    • The remaining plastic clips should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
  11. LG G3 Rear Facing Camera Replacement, Motherboard: шаг 11, изображение 1 из 2 LG G3 Rear Facing Camera Replacement, Motherboard: шаг 11, изображение 2 из 2
    • Use a spudger to pry up and disconnect the display flex cable.
  12. LG G3 Rear Facing Camera Replacement: шаг 12, изображение 1 из 2 LG G3 Rear Facing Camera Replacement: шаг 12, изображение 2 из 2
    • Use a spudger to pry up and disconnect the digitizer flex cable.
  13. LG G3 Rear Facing Camera Replacement: шаг 13, изображение 1 из 2 LG G3 Rear Facing Camera Replacement: шаг 13, изображение 2 из 2
    • Use a spudger to pry up and disconnect the rear camera flex cable.
  14. LG G3 Rear Facing Camera Replacement: шаг 14, изображение 1 из 2 LG G3 Rear Facing Camera Replacement: шаг 14, изображение 2 из 2
    • Use a spudger to pry up and disconnect the front camera flex cable.
  15. LG G3 Rear Facing Camera Replacement: шаг 15, изображение 1 из 2 LG G3 Rear Facing Camera Replacement: шаг 15, изображение 2 из 2
    • During these next few steps, make sure to avoid damaging the flex cables you disconnected.
    • Slide an opening pick under the bottom right corner of the motherboard and slowly pry it out of its recess by rotating the opening pick sideways.
  16. LG G3 Rear Facing Camera Replacement: шаг 16, изображение 1 из 2 LG G3 Rear Facing Camera Replacement: шаг 16, изображение 2 из 2
    • Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways.
  17. LG G3 Rear Facing Camera Replacement: шаг 17, изображение 1 из 2 LG G3 Rear Facing Camera Replacement: шаг 17, изображение 2 из 2
    • Grab the top section of the motherboard and carefully lift it out of the phone.
  18. LG G3 Rear Facing Camera Replacement, Rear Facing Camera: шаг 18, изображение 1 из 2 LG G3 Rear Facing Camera Replacement, Rear Facing Camera: шаг 18, изображение 2 из 2
    • Take the plastic opening tool and remove the rear-facing camera by wedging it into the sides and lifting up
    • The rear-facing camera is kept in place with a double-sided tape, so it may take some time and effort to get it out. Attack it from all sides
  19. LG G3 Rear Facing Camera Replacement: шаг 19, изображение 1 из 1
    • Remove the old rear-facing camera
Заключение
26 участников успешно повторили данное руководство.
Shannon
Участник с: 10/15/14
1 610 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 1-3, Duarte Fall 2014 Участник UMass Dartmouth, Team 1-3, Duarte Fall 2014
UMASSD-DUARTE-F14S1G3
4 членов
Автор 10 руководств
7 Комментариев
perfect. Camera had stopped functioning on my G3 (due to some clumsiness on my part). Followed the steps and disconnect camera ribbon, then reconnected and reassembled. Now all functioning perfectly.
Andy Corps - Ответить
how was it not functioning? Mine suddenly wont even detect that there is a back camera and I am debating whether to try this and risk ruining the phone or just spending the extra cash and having it done professionally since I can't get a new one until april.
Claire Robbins -
Mine the camera started crashing 'unfortunately camera stopped' but the selfie cam worked. Reset did nothing have to try this.
Gad Mugane - Ответить
Will the phone work with out the camera in it?
Mike Kizer - Ответить
Excellent guide.    Bad auto focus, replaced -> works !
Would add in step 6, top panel is held on by small plastic tabs on the edges.
As with all electronic dis/assembly, make sure take appropriate anti-static precautions.
Jonathan Ling - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 20,514
