Введение
The rear speaker is attached to the bottom panel of the LG G3, so to resolve any problems with the rear speaker, a full replacement of the bottom panel is necessary.
Video Overview
  1. Take your phone and place it screen down.
    • Take your phone and place it screen down.
  2. Start by lifting the back panel using the gap located on the bottom-left side of the phone. Insert the plastic opening tool into the gap and move it along the edge of the phone until the rear case pops off. Insert the plastic opening tool into the gap and move it along the edge of the phone until the rear case pops off.
    • Start by lifting the back panel using the gap located on the bottom-left side of the phone.
    • Insert the plastic opening tool into the gap and move it along the edge of the phone until the rear case pops off.
  3. Remove the battery from the phone. Remove the battery from the phone.
    • Remove the battery from the phone.
  4. Apple Watch Kits
    Screen and battery repairs just got easier.
    Купить сейчас
    Apple Watch Kits
    Купить сейчас
  5. Remove the 13 screws found on the back of the phone. The screw circled in red is shorter than the other 12 screws. For an easier time when reassembling the phone, store it separately from the other screws.
    • Remove the 13 screws found on the back of the phone.
    • The screw circled in red is shorter than the other 12 screws. For an easier time when reassembling the phone, store it separately from the other screws.
  6. Locate the same gap used in the earlier step Lift gently using your fingers
    • Locate the same gap used in the earlier step
    • Lift gently using your fingers
  7. Remove the bottom panel
    • Remove the bottom panel
  8. remove the speaker from the rear panel and insert the new speaker
    • remove the speaker from the rear panel and insert the new speaker
Заключение
8 участников успешно повторили данное руководство.
Shannon
Участник с: 15.10.2014
1 460 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 1-3, Duarte Fall 2014 Member of UMass Dartmouth, Team 1-3, Duarte Fall 2014
UMASSD-DUARTE-F14S1G3
4 членов
Автор 14 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 5
За 30 дней: 21
За всё время: 13,488
