ΠŸΠ΅Ρ€Π΅ΠΉΡ‚ΠΈ ΠΊ основному ΡΠΎΠ΄Π΅Ρ€ΠΆΠ°Π½ΠΈΡŽ
Π’Ρ‹Π±Π΅Ρ€Π΅Ρ‚Π΅ Ρ‚ΠΎ, Ρ‡Ρ‚ΠΎ Π²Π°ΠΌ Π½ΡƒΠΆΠ½ΠΎ
  1. LG G5 Charging Port Replacement, Battery: step 1, image 1 of 3 LG G5 Charging Port Replacement, Battery: step 1, image 2 of 3 LG G5 Charging Port Replacement, Battery: step 1, image 3 of 3
    • Power down the phone by holding the power button for several seconds.
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Charging Port Replacement: step 2, image 1 of 2 LG G5 Charging Port Replacement: step 2, image 2 of 2
    • Separate the battery from bottom half.
    • Insert the new battery in the same position and orientation as the old battery. Match up the arrows to be sure the orientation is correct.
  3. LG G5 Charging Port Replacement, Charging Port: step 3, image 1 of 2 LG G5 Charging Port Replacement, Charging Port: step 3, image 2 of 2
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
  4. LG G5 Charging Port Replacement: step 4, image 1 of 2 LG G5 Charging Port Replacement: step 4, image 2 of 2
    • Insert the plastic opening tool into the bottom seam
    • Pry the plastic from the base only a slight amount.
  5. LG G5 Charging Port Replacement: step 5, image 1 of 2 LG G5 Charging Port Replacement: step 5, image 2 of 2
    • Remove the one 5.5mm Phillips #000 screw.
  6. LG G5 Charging Port Replacement: step 6, image 1 of 3 LG G5 Charging Port Replacement: step 6, image 2 of 3 LG G5 Charging Port Replacement: step 6, image 3 of 3
    • Insert the plastic opening tool into the seam between the two plastic layers.
    • Pry the plastic from the body.
  7. LG G5 Charging Port Replacement: step 7, image 1 of 2 LG G5 Charging Port Replacement: step 7, image 2 of 2
    • Insert the plastic opening tool into the seam under the metal charging port.
    • Pry the metal charging port from the body.
Π—Π°ΠΊΠ»ΡŽΡ‡Π΅Π½ΠΈΠ΅
23 участников ΡƒΡΠΏΠ΅ΡˆΠ½ΠΎ ΠΏΠΎΠ²Ρ‚ΠΎΡ€ΠΈΠ»ΠΈ Π΄Π°Π½Π½ΠΎΠ΅ руководство.
Joshua Zalmanowitz
Участник с: 27.09.2016
1Β 799 РСпутация
Автор 4 руководств
Cal Poly, Team 18-2, Forte Fall 2016 Участник Cal Poly, Team 18-2, Forte Fall 2016
CPSU-FORTE-F16S18G2
4 Ρ‡Π»Π΅Π½ΠΎΠ²
Автор 15 руководств
13 Comments
I would love steps to show not only pulling out the usb port, but also putting the new one in and re-assembly. Also maybe tips about things to avoid doing -- easy slip ups people make when doing it. Why replace just the usb port instead of the whole board assembly or instead of the entire bottom module? Thanks! Great pics
jessicacollins267 - ΠžΡ‚Π²Π΅Ρ‚ΠΈΡ‚ΡŒ
Anyone know how to bypass the "insert a supported module" error that comes up after changing the charging port?
Rene - ΠžΡ‚Π²Π΅Ρ‚ΠΈΡ‚ΡŒ
Do you solve the problem? Can you help me, please?
Budai Daniel -
I need to do this repair on my phone, but Rene's comment worries me. Does this error message come up often? Can it be fixed?
Brad - ΠžΡ‚Π²Π΅Ρ‚ΠΈΡ‚ΡŒ
Hello. I have the same problem like Rene . I changed the usb port and when I try to power on my smartphone it shows me the picture that said β€œinsert a supported module” like what Rene said earlier. Please, I need help.
Budai Daniel - ΠžΡ‚Π²Π΅Ρ‚ΠΈΡ‚ΡŒ
Π”ΠΎΠ±Π°Π²ΠΈΡ‚ΡŒ ΠΊΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ
ΠŸΡ€ΠΎΡΠΌΠΎΡ‚Ρ€ статистики:
Π—Π° послСдниС 24часов: 5
Π—Π° послСдниС 7 Π΄Π½Π΅ΠΉ: 15
Π—Π° послСдниС 30 Π΄Π½Π΅ΠΉ: 63
Π—Π° всё врСмя: 23,258
